2$ fix for cracked cb carb boots
my air tubes on my cb are severly cracked. last night i had an idea...
here you go, get a bicycle inner tube. pump it up and let it sit for a day to help stretch the rubber.
smear synthetic grease all over your boot. empty tube of air, cut a piece about twice as long as your boot. carefully stretch and slide it over your damaged boot. let it relax for a day and trim any overlap off. i used a bell universal 26" tube because its what i had. you can even get the tube seam to line up eith the original seam on the boot. it looks very presentable and it certainly wont leak. hope this saves you folks a few bucks. p.s. the task was not easy stretching the tube over, so be prepared the use extra elbow grease!
bikedoctor99
alternative rubber lubricant
isopropyl alcohol will make that job much easier and when dry doesn't leave any residual lube that could cause future problems in certain applications. i keep a spray bottle with isopropyl handy for some seal installations, weather sealings, etc. will also work to "seat" standard tire beads- tubeless will require tire lube (auto store). hope you will find this helpful,allan
