I just got my carb rebuild kit in the mail today from a 3rd party distributor *it's probably etiquette to leave dealers name out*
I asked the dealer to send me over the spec sheet for the correct air/fuel mixture turns, and the float level hight. All i want to know is if this sounds correct for my CP77 Keihin PW26 carburetors.
This is his message:
Hi Estevan, The float height on the CB77 floats is 26mm, now the Air/fuel
mixture screw on the carbs is 1 1/2 turns out from dead bottom. Any
questions call XXXXXXXXXXXX between 10am and 5:30 pm EST....
Sound right? Any preferences to when you are putting back your carb floats and air/fuel screws?
Carb Rebuild - putting back together.
Ya fellers don't recall how I adjust the float?. .........lm
marlin4622 wrote:i am almost positive that there is no difference between cb and cp. what do you use to adjust the carb height? micrometer? or a special tool? i just looked up on youtube a guy making a DIY on float height and he uses a drill bit.. haha.
What do you use brewsky?
Yep....forgot.....as I am used to the Dream carb.LOUD MOUSE wrote:Ya fellers don't recall how I adjust the float?. .........lm
