when i installed my petcock to the tank the lever seems to bind and really hard to turn the gas on and off i might be tightening the screws to much but i also want to make sure i compress the O-ring gasket so it doesnt leak.
when it's off the tank the lever moves really smooth and easy.
any suggestions???
thanks
G-gaurd
petcock binds when installed
paperslammer
Re: petcock binds when installed
Mine did the exact same thing...was real tight to begin with, but has loosened up over time.G-GAURD wrote:when i installed my petcock to the tank the lever seems to bind and really hard to turn the gas on and off i might be tightening the screws to much but i also want to make sure i compress the O-ring gasket so it doesnt leak.
any suggestions???
thanks
G-gaurd
Recently had mine apart to change tanks, and noticed the rubber washer with the holes had begun to tear where the lever slides over the holes, so I will be needing a new one shortly.
Paperslider probably has good a recommendation there.
Next time I will try to find the cork type OEM washer.
