A brought a couple of Keyster Carb Kits for my 66 CB77 and it came with 100 mains instead of 135's. I know that not all jet manufacturers will use the same unit for measure and the actual hole in the jet will be the same in for both jets even though they have a different number stamped in the jet - or vise versa.
Does any one know if this is true for these kits or have any experience with the Keyster rebuild kits. I have 145's in the bike now (thats what it came with) and the bike is obviously running pretty rich. I'm running Emgo pipes and stock air filters. I was considering running the 100's but figured I would ask before I went too far.
The needles in the Keyster kits were a little larger as well - has anyone noticed this? I pretty much used the bowl gasket, drain washer, and needle and seat since most of what came with the kit was different. I'm just not sure how many components are actually original in my carbs.
Was there a jet kit available that had thinner needles by chance?
Thanks,
Byrd
Keyster Carb Kit came with 100 mains
The needles still won't be correct, and the jets are iffy. I've used the jets with varying results, but the needles are unusable. Check to see if the ones that you have are indeed the stock ones, and stick with those. I agrre that retro bikes is awsome. Great parts, great prices, and excellent service, a rarity these days!
