Gas flow
Post by davomoto » Sun Jul 17, 2011 8:30 pm
Hotshoe wrote:Could it be a plugged gas tank vent?
Not familar with CAs but CLs have a vent hole in the gas cap that can cause similar problems when plugged.
I hear you about the weather, if it's not blazing hot it's raining here, hurry up October.
Yes, good one! That could be it as well!
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Eck
Post by Eck » Mon Jul 18, 2011 9:30 am
I'll check the vent out tonight, how would one polish the valve seat.
Thanks for the help guys. It is only going to be 105 today!
Kirk
brewsky
Post by brewsky » Mon Jul 18, 2011 11:07 am
I use a Q-tip moistened with water and dipped in baking soda.
Cut the Q-tip in 2 and chuck it in a drill, and it is a perfect fit for the diameter of the float valve seat.
I've also heard of others using Honda metal polish, but it may leave some sort of protective residue that may need to be removed, so I haven't tried that.
It may be overkill, but who knows for sure?
I've had the exact same issue before, only to take the carb apart and find nothing wrong, put back together and re-install and the problem goes away, for a while.
FAST FRED
TOOTH PASTE
Post by FAST FRED » Mon Jul 18, 2011 12:56 pm
Back in the day we used tooth paste to lap in our promlematic float valves. Remove float valve from carb, hold seat in one hand add a dab of tooth paste and insert valve and twist back and forth about a dozen times, clean with water and than carb cleaner. Reinstall and test, repeat if nessesary.
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
brewsky
Re: TOOTH PASTE
Post by brewsky » Mon Jul 18, 2011 1:09 pm
FAST FRED wrote:Back in the day we used tooth paste to lap in our promlematic float valves. Remove float valve from carb, hold seat in one hand add a dab of tooth paste and insert valve and twist back and forth about a dozen times, clean with water and than carb cleaner. Reinstall and test, repeat if nessesary.
Fast Fred
Yep...."back in the day" that would have worked for me.....now it would be Polident or a special trip to the store for paste!
Blanas
Post by Blanas » Tue Jul 19, 2011 5:21 pm
Check out your gas line connection to your carb. I found that sometimes there is a screen there and after many years it rusts and clogs up, restricting the flow of gas.
Blanas
Post by Blanas » Tue Jul 19, 2011 5:27 pm
Also check that your float moves freely with no restrictions. If so you can bend it a little so it dosnt hang up.
