VERY GOOD!
Glad you got things sorted out, and ONCE AGAIN A BIG THANK YOU TOO LOUD MOUSE for his willingness to help. And fortunate for TG he himself was nearby! Doesn't get much better!
Ran great, now bogs down, choke makes no difference.
Well after Ed put the right jets in and set my float at 26.5 mm, I put the carb back on and the Dream started right up first kick! We used Keihin 120 main and 35 slow, but using a Keyster D3 needle for now as compared to the Keihin 22401 (stamped) Will swap it out once I get one and will report back with the comparison.
Thanks again to Ed! BTW Ed, I checked the float with my gauge to make sure mine was accurate, and it was right on the gnat's arse, just the way you set it.
That's good news
Now for a good ride tomorrow. .......................lm
texasgrape wrote:Well after Ed put the right jets in and set my float at 26.5 mm, I put the carb back on and the Dream started right up first kick! We used Keihin 120 main and 35 slow, but using a Keyster D3 needle for now as compared to the Keihin 22401 (stamped) Will swap it out once I get one and will report back with the comparison.
