As for electrical. I suppose extreme heat could alter the operation of a condenser. But the coil doesn't get much heat inside the gloss white side cover, shaded by the rider's thigh; so it's not likely the coil. But you're the second to mention the condenser as something to consider. I could put the "shop hair dryer" to it before a ride to see if it triggers the symptom sooner. And I do have a spare condenser... And I'll open the side cover and feel the coil if/when the engine acts up and see if it's unusually hot, just to be sure. Or maybe I'll run around with the side cover off...
mike in idaho wrote:If it's not a carburetion issue, maybe it's a fuel related issue. Have you tried a different grade of gas? Maybe some ethanol free blend(if you can find it). Maybe it's electrical, do you have a way to heat up the coil/condenser(with a heat gun or a hair dryer) to see if it acts up?
