djg422 wrote:I think theres enough lip where i could just clamp a fuel line onto the carb. Would this be ok while a wait to find a new carb? Does the stock banjo bolt set up provide a specific rate of fuel entering the float bowl? Thanks!
Fuel Line into Carb Banjo Bolt
I have used this stuff to repair threads. It works if you don't need to torque the bolt real tight.
http://www.permatex.com/products/Automo ... Repair.htm
It's a two part epoxy you put on the stripped threads, there is a release agent that goes on the good threads. After it cures, you can remove the bolt or tighten it. It might be something to try if your solution doesn't work. I wouldn't trust it as a permanent fix. I found it at auto parts stores.
Gunner
Gunner
