Gun wrote:I'll get to figuring out how to adjust the slide heights properly.
Sticky slides cured!
Turn out the slide screws and allow the slides to bottom on the carbs. Put your thumb in the right side carb and middle finger in the left. Push real hard on the slides and twist the grip to raise the slides. If one lifts before the other you need to screw the cable adjuster on the other carb so both lift at exactly the same time. Lock the adjusters and test again. Turn both screws in a turn and start engine then adjust slides for idle. ..........lm
RIDE IT DON'T HIDE IT!
