It's back! Hesitation (again)
Thats a lot of things that differ from stock/recommended. So i'm not sure that I have any advice worth listening too. I would entirely document the current carb settings so you can return to these as known running configuration... then start with a new throttle cable, move back to stock settings/needles/jets/float, and make slight adjustments until resolution. stock float setting shouldn't induce flooding, so I'm thinking there is something else amiss in there.
'65 CB77
'66 CB450k0
'93 HD FXR
'66 CB450k0
'93 HD FXR
Well, I am worried I F'ed up the float adjustment.
I have two law degrees, and I still was baffled by the long discussion/debate over float settings on the forum!
When I take the bowls off, there is gas over the lip of the tilted bowl.
Ie, when you break it open, gas comes out.
Seems like a proper setting should have gas in the bowl up to the front lip of the bowl when tilted as installed, but not over it. Maybe I am wrong about that.
I set it to 23mm, and also eyballed it as per the forum.
Then I backed it off some because of the leaking.
Maybe I just have bad gaskets.
I am loath to touch anything further, as this is the best running the bike has been in three months.
