Carburetor intake insulator and o-ring damage
SWARDLAW
Post by SWARDLAW » Thu May 15, 2014 7:19 am
The original material was a form of phenolic and is mostly resin. The phenolic material is used because it is a great heat insulator and it's very good material when used with gasoline. The problem with the oring design that Honda used is that as the oring is clamped down between the carb and spacer it pushes out and breaks the lip off the old phenolic spacer. Wood of any kind would work for a while but would soon absorb the gas and start to break down. I tried to use aluminum but it didn't insulate the carb from the heat of the head and cylinder. Phenolic is still the best material and easy to find in different thicknesses. Glad to see the gaskets worked.
Snakeoil
Post by Snakeoil » Thu May 15, 2014 11:34 am
I found several sources for phenolic material. I had originally wanted to make it from Textolite. We used that material in generator insulation and support systems. Not sure if the textile fabric would absorb gasoline over time. Plus, I just could not score any thru my old work cronies.
The gasket is simple and fool-proof.
regards,
Rob
SWARDLAW
Post by SWARDLAW » Thu May 15, 2014 7:46 pm
The only problem with the paper gasket is that the carb never pulls up as tight as the phenolic and o-ring setup. I made sure to use small lock washers to keep the nuts from backing off. These bikes like to vibrate and I have added 242 (blue) Loctite to every bolt and nut on the bike.
Snakeoil
Post by Snakeoil » Fri May 16, 2014 9:35 am
Actually, it does. Keep in mind that there is another o-ring between the carb and the insulator. That o-ring maintains the constant tension.
I have resisted putting Loctite on the carb nuts because it is so damn difficult to get the nuts onto the carbs given the limited working space. Loctite would make a hard job even harder.
I'll double check the nuts on the carbs. Can't hurt.
Back in my formative years, my friend had a brand new '72 Commando. I was on the back. We stopped at a light and another bike pulled along side. I looked over and the rider on that bike pointed down at the engine on the Norton. I looked down and could not believe my eyes. Both carbs were loose. I would never believe in a million years that a bike would run in that condition. But it was running. We pulled over and there was only 1 nut left on each carb. He screwed them down, finger tight and we headed for home. True story.
regards,
Rob
garncarz
Post by garncarz » Fri May 16, 2014 10:49 am
Snakeoil wrote:Actually, it does. Keep in mind that there is another o-ring between the carb and the insulator. That o-ring maintains the constant tension.
So, the order would be, from inside to out: Head, paper gasket, carb spacer, o-ring and then carb.
Or: Head, paper gasket, carb spacer, paper gasket, o-ring, carb.
Snakeoil
Post by Snakeoil » Fri May 16, 2014 8:50 pm
First one.
Head
Paper gasket
Insulator
O-ring
Carb flange
This is the same set-up that Triumph used. Only different is the inclusion of a separate intake manifold. A typical mod to Triumphs is to eliminate the insulator and use a thicker section o-ring. It has to be held in place with grease during installation. The studs/bolts are tightened only enough to squeeze the o-ring a sufficient amount and leaves an air gap between the manifold flange and the carb flange. Air is a great insulator. That would have been a possible solution if the intake hoses were long enough to reach the filters. But I don't think there would be enough engagement.
regards,
Rob
garncarz
Post by garncarz » Sun May 18, 2014 7:06 am
I also oiled the paper gasket. Runs well in this configuration. Thanks all.
