slides down high revs
Post by LOUD MOUSE » Wed Nov 23, 2011 12:16 pm
Turn both to the bottom and go back to the FAQ and adjust from that.
If the slide is only a little to high the engine will do as yous does. .......lm
drab wrote:ok.... will drop as much as it will let me....
If I adjust the nuts at the top of the carb and the resulting level of the slides are different, is this something that I can fix with the slide screw? Adjust one side to compensate for the other?
Is there anything at the throttle grip I can do as well? The small adjusting nut there?
best
d
Post by davomoto » Wed Nov 23, 2011 12:19 pm
Also,
Your pics show that you have one brass slide, and one hard anodized aluminum slide. I don't see any reason why they wouldn't work that way.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Post by LOUD MOUSE » Wed Nov 23, 2011 12:56 pm
They will. ..........lm
davomoto wrote:Also,
Davo
