For those who wish to fabricate their own float height gauge
Torque hammer
Brew, I gotta get me one of those.................D
Re: Torque hammer
I can build one if I had the blue print!....:-). .......lm
stratone wrote:Brew, I gotta get me one of those.................D
This was posted awhile back, but never did see a response as where to measure from (CL77, 26mm carbs.). gasket surface, top of the slight ridge on the gasket surface, top of the recess cutout, or top of the bowl centering lip.Bee wrote:I see the gauge you fabricated is measuring from the notch in the bowl while my CL77 manual shows measuring from the top of the bowl 26.5mm. Now I'm not clear on where to measure, any help? Also does anyone know the size on the bolts that hold the petcock to the tank of a CL77? I left the bolts in the tank when I sent it out for painting they lost them.
TIA
You measure from the CUT OUT without the gasket or you can look at the FAQ on the forum under "HOW I TUNE" and make it easy. .................lm
gbyoung2 wrote:This was posted awhile back, but never did see a response as where to measure from (CL77, 26mm carbs.). gasket surface, top of the slight ridge on the gasket surface, top of the recess cutout, or top of the bowl centering lip.Bee wrote:I see the gauge you fabricated is measuring from the notch in the bowl while my CL77 manual shows measuring from the top of the bowl 26.5mm. Now I'm not clear on where to measure, any help? Also does anyone know the size on the bolts that hold the petcock to the tank of a CL77? I left the bolts in the tank when I sent it out for painting they lost them.
TIA
You've basically answered my question, so thank you. Couldn't figure out where you were trying to tell me to look, but that's alright; we're good.LOUD MOUSE wrote:You measure from the CUT OUT without the gasket or you can look at the FAQ on the forum under "HOW I TUNE" and make it easy. .................lm
TIA
EDIT: I should have added that I have one of the Pit Posse gages, so no need to fabricate a dedicated one for the CL77.
Well if you read what I recommended you don't MAKE ANYTHING!. .......................lm
gbyoung2 wrote:You've basically answered my question, so thank you. Couldn't figure out where you were trying to tell me to look, but that's alright; we're good.LOUD MOUSE wrote:You measure from the CUT OUT without the gasket or you can look at the FAQ on the forum under "HOW I TUNE" and make it easy. .................lm
TIA
and you will see the tuning and how with what that makes that engine work. .......................lm
TIA
