Newbie carb guide
some kind of screw ?
Hey thanks for that, but this isn't the idle adj screw- it's the other one. This is a single carb on a CA77. It's a adj. screw on the carb- not the big one that goes into the slot on the slide,and it's broke off flush ! Probably have to get another carb-$!
broken idle screw
Try a grab it, they sell them at pep boys. It's the best tool I've ever used for a broken screw head. Just make sure you don't damage the carb when you do it, but if your going to buy a new carb any how, what do you have to lose.
Good luck.
Good luck.
Ricardolobo
Me too, THANKS wolftrain44@msn.com
broken idle screw
The grab it still might work, just use the smallest bit there are two, one to grab it and one to pull it out using a reverse drill. It might keep you from having to buy a knew carb.
Hello. Could I please have a copy of that carb adjustment file. I would greatly appreciate it.
Thankyou
Forest
charmcity25@yahoo.com
Thankyou
Forest
carb guide
could you email this? fournations@comcast.net
thanks,nation
thanks,nation
