main jet holder unobtainable?
chiboy002
Post by chiboy002 » Wed Jul 13, 2011 10:44 pm
[quote="teazer"]
No. You are correct. Needle jet in those carbs is a simple stepped piece of brass. Almost all slide carbs are 2.60mm needle jets but the heights vary from one to another.
It's that jet holder/emulsion tube that has cross drilled bleed holes.
You could probably drill the bleed holes out with a 1/16" drill bit and clean up the top face and drill it through with a 7/64" drill bit until you find a replacement.[/quote]
I have one on the way from ohio cycle but yeah i plan on cleaning them up so i can have it as a spare. Thanks for the drill sizes
I havent tried starting it as i'm waiting on clutch parts but once those arrive and the motor is back together i'll let you guys know whats up.
I don't really know where to start with the cl72 carb on a 90cc engine ha.
THanks fellas
cron
