spark + compress + fuel + air = no start
dkwilfert
Post by dkwilfert » Mon Jul 06, 2009 6:55 pm
Explain "no continuity to ground" in this context.
If the starter were connected, there would be a path to ground through the starter. Once the starter is disconnected, there is no longer a designed path to ground for that terminal (post). The other big post would normally be connected to the battery + so it is not grounded either; therefore, neither of the big terminals (posts) should have a path (continuity) to ground.
versuspop
Post by versuspop » Tue Jul 07, 2009 6:20 am
So..through testing, I determined that my frame was hot. I continued to get weird readings from the solenoid also. eventually realized that the pos was sending power to the solenoid and the solenoid was sending power to the frame. The copper piece on the bottom side of the positive terminal on the solenoid had gotten turned and was touching the solenoid body. Thus the current through the bike frame. I repaired it, and I can reconnect the battery as normal.
On to the petcock.....
Post by davomoto » Tue Jul 07, 2009 6:15 pm
Congrats on finding the problem, and good on ya for posting the solution!
versuspop
Post by versuspop » Wed Jul 15, 2009 9:09 pm
still can't get the bike to start!!!!!!!!!!
it will turn over for a second, start and the die.
gas filling up float bowl and leaking out.
thought for sure i had solved the problem!!!!!
at a complete loss at the moment.
any suggestions???
versuspop
Post by versuspop » Wed Jul 15, 2009 9:10 pm
can the actual carb go bad?
mike horvath
Post by mike horvath » Wed Jul 15, 2009 9:41 pm
Don't know about actually "going bad", but with the air filters off, and using a mirror and a flash light, can you see gas spilling up into the throat of the carb? Are you over flowing one, or both? If you haven't already, check the bowl float valve(s) to be sure it isn't stuck in the up/open position. Another thought, will it overflow with the tank gas cap off?
Mike
versuspop
solved!!
Post by versuspop » Wed Sep 16, 2009 4:18 pm
the body jets in the carb were clogged...compressed air is my friend....bike starts and runs great!!!
