rebuilt carbs-great start- and then two days later-no good
allthumbs
Post by allthumbs » Sat Sep 20, 2008 4:55 pm
the fuel lines were clear, bowls empty when i removed them. I jiggled the floats and nothing. then I removed the carbs with the lines still attached and jiggled the floats and gas flowed. reassembled and started her up. runs good now.
could be the root of a bigger problem? I suppose I'll have to go over through the carbs again to make sure.
strange
thx
mike69
rebuilt carbs
Post by mike69 » Sat Sep 20, 2008 5:52 pm
Glad you got it going. Mike
66 Dream
78 Goldwing
Post by e3steve » Sat Sep 20, 2008 5:53 pm
The fuel recipe I read about was from a fellow on the board that used it in all his 4 stroke machines to keep everything lubed nicely, including the slides. mine were sticky even after cleaning and rebuilding so I figured I'd give it a try.
Look, bro', 'sticky' just isn't right. Strip the carbs & clean with isopropanol or industrial (96%) alcohol to get rid of the sticky shit. After a rebuild, carbs should be surgically cleansed!
Post by e3steve » Sat Sep 20, 2008 6:01 pm
allthumbs wrote:the fuel lines were clear, bowls empty when i removed them. I jiggled the floats and nothing. then I removed the carbs with the lines still attached and jiggled the floats and gas flowed. reassembled and started her up. runs good now.
strange
thx
Mate, still reckon there's a shed-load-of-shite in the petcock/bowl/tank! Otherwise, what could be causing the carbs' floatbowls to not fill? C'mon, logical approach; work back through the prob....
allthumbs
Post by allthumbs » Sat Sep 20, 2008 6:10 pm
afraid you gotta be right e3steve, I got to check it in the am. even tho I checked that thing a million times. the tank looks clean but can't see everywhere in it. BUT fuel filters should show some crap, or at least allow flow. they just seemed to hinder it all. we'll see what comes out in the wash.
thx
Post by e3steve » Sat Sep 20, 2008 6:14 pm
If you've used a silicon-based sealer on the petcock then nothing will manifest itself in the fuel system (not even fuel!). That stuff will stop an oil pump, me ol' mucker....
allthumbs
Post by allthumbs » Sat Sep 20, 2008 6:32 pm
used very sparingly at the last threads from the openings. not silicone, still pliable. probably crap in the tank. good thing I got a parts bike..
