145 Main Jet
145 Main Jet
Good evening everyone!
I recently acquired a set of Keihin 26 mm carburetors that contain 145 main jets and 42 slow jets. The bowl is also just a bit differently shaped than the ones removed from my '67 CL77 (contains a slight outward bend in the middle on the engine side). The needle jet is marked 24231 which I believe meant for a CB77. Would a CB77 really use a 145 jet? Also, would it be a problem to use the 145's and the 24231 needle on my CL77? These carbs are in really good condition. Pictures below.
Thanks for your interest!!
MrBurnn
MrBurnn
- IMG_1259.JPG (37.69 KiB) Viewed 3204 times
- IMG_1257.JPG (33.62 KiB) Viewed 3204 times
Re: 145 Main Jet
They are Round Bowl carbs.
Unless your carbs are BAD I would not use them.
For jets and needle the CL77 will run well with 135 42 and the needle should be OK. ..................lm
quote="Mrburnn"]Good evening everyone!
MrBurnn[/quote]
MrBurnn[/quote]
They are not the correct issue carb for your bike and YES. ................lm
Mrburnn wrote:Thank you Loud Mouse!
May I ask why not to use the round bowl carbs? My square bowl carbs are good enough to use, I am just curious as to the difference between the two types. Also, are the 145 jets too big to use on a CL77?
Thanks again!
MrBurnn
