Game: What the hell happened to this carb?!?
Took the carb off my CA77 and broke it open and well...not quite sure what the hell it is. I have never seen anything like it...
Anyone?
Anyone?
- th_P1020933.jpg (4.25 KiB) Viewed 7150 times
- th_P1020934.jpg (3.94 KiB) Viewed 7150 times
- th_P1020931.jpg (4.62 KiB) Viewed 7150 times
- th_P1020930.jpg (3.81 KiB) Viewed 7150 times
- th_P1020929.jpg (3.61 KiB) Viewed 7150 times
Superchicken
Re: Game: What the hell happened to this carb?!?
The answer to your original question is. WATER got in it and evaporated and what you saw was the reaction of the water to the metal and the calcium is what's left. Very common. ....................lm
Githianki wrote:Took the carb off my CA77 and broke it open and well...not quite sure what the hell it is. I have never seen anything like it...
Anyone?
The buildup didn't eat the aluminum, the buildup IS the aluminum! Only now it's aluminum oxide! Which isn't very good for making a carburator because it has very loose molecular bond now that it's taken the oxygen molecules out of the water. But I bet if ya had a big enough aluminum float bowl and let the water sit in it for long enough, you could run it around the block on the leftover hydrogen!
