Carb. Sliders - Oops
sstaylor
Post by sstaylor » Mon Jul 17, 2006 9:46 pm
Greetings,
This may be common knowledge, but while working on my bike, using the Bill Silver books, I noticed a suggestion to verify that the correct carb sliders were in the correct carbs. The book stated that if they were reversed, the engine would run way too rich. I checked, and sure enough, mine were in bass-ackwards.
FYI,
Scott
piecutter
Post by piecutter » Tue Jul 18, 2006 1:05 am
I RESEMBLE THAT REMARK!
Joe Bass
ggray
Sliders
Post by ggray » Fri Aug 11, 2006 10:08 pm
OK, so for those of us without Bill Silver's book, How do we determine whether they're in backwards or not?????????
Gary
'65 CL77 Owner
jesmed
Post by jesmed » Thu Oct 19, 2006 11:20 am
Gary, you probably figured this out long ago, but for those who haven't...the bottom edge of the slide has a slight upward-curving cutout or relief on one side. This relief has to be facing away from the engine, i.e. you should be able to see it when you look into the carb from the intake side. If you look into the carb from the intake side and don't see a slight upward curve to the lower edge of the slide, your slides are in backwards.
ggray
Carb sliders
Post by ggray » Thu Oct 19, 2006 9:13 pm
Thank you for the clarification.
Gary
'65 CL77 Owner
