Fuel Line into Carb Banjo Bolt
Post by LOUD MOUSE » Fri Apr 30, 2010 9:23 am
OH YA!!!!!!!!!!!!!!!!!!!. ...............lm
djg422 wrote:I think theres enough lip where i could just clamp a fuel line onto the carb. Would this be ok while a wait to find a new carb? Does the stock banjo bolt set up provide a specific rate of fuel entering the float bowl? Thanks!
Post by davomoto » Fri Apr 30, 2010 9:30 am
I would try epoxying the banjo in to the carb before trying to clamp a hose on the outside of it. Problem is if it leaks, comes loose etc, hot engines and gasoline are not a good combination!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
djg422
Post by djg422 » Sun May 02, 2010 9:50 pm
yeah, thats valid advice! I ended up tapping the hole to fit a fuel valve into. Im just gonna hope it works as a I look for a replacement.
Gunner_CAF
Post by Gunner_CAF » Mon May 03, 2010 12:42 am
I have used this stuff to repair threads. It works if you don't need to torque the bolt real tight.
http://www.permatex.com/products/Automo ... Repair.htm
It's a two part epoxy you put on the stripped threads, there is a release agent that goes on the good threads. After it cures, you can remove the bolt or tighten it. It might be something to try if your solution doesn't work. I wouldn't trust it as a permanent fix. I found it at auto parts stores.
Gunner
djg422
Post by djg422 » Tue May 04, 2010 6:11 pm
thanks!
