CL77 drain screw washer replacement
AZscrmblr
Post by AZscrmblr » Wed Jun 10, 2020 11:10 am
I have a CL77 that is leaking fuel around the drain screw on the left carburator. I believe the fiber washer sealing the drain screw has OD = 8mm and ID = 6mm. Can someone confirm that. Where is a good source for either the red fiber or a metal crush washer replacement for this washer?
