Slow/idle jets for CL77 at higher elevation
RetroBiker
Post by RetroBiker » Fri Oct 10, 2025 5:19 pm
Hi everyone,
I've been having idling issues with my newly rebuilt engine, so I checked the slow/idle jets and the right hand cylinder (which was not running properly) had a blockage in the slow jet! After some work I cleaned it out, and while the bike runs now it still is not idling great no matter what I do with the air or throttle stop screws. I'm in Denver at over 5,000 feet of elevation, and some info I've found online suggests I try smaller jets (i.e. #38 or #40). Currently I've got #42's for idle jets.
Does anyone have experience with higher elevations and does this suggestion of using smaller jets make sense to you? If so, does anyone have a pair of good OEM idle jets in these sizes I might be able to purchase? Ebay is filled with options, but I'm leery of buying foreign aftermarket parts. I have enough challenges already. :-)
Thanks Guys.
Tim Allman
Re: Slow/idle jets for CL77 at higher elevation
Post by Tim Allman » Mon Oct 13, 2025 2:45 pm
I was just looking at the Honda Common Maintenance Repair Service Manual (section 8) and see that they recommend adjusting the idle screw for high altitude and installing a smaller main jet. Keep in mind that the main jet will have little, if any, effect on the idle so it won't help your problem.
mike horvath
Post by mike horvath » Tue Nov 04, 2025 10:05 pm
Retro-
Late post I know, but adjusting either carb air fuel mixture screw has no effect? Maybe timing is off.
1966 CL77 (sold)
1978 CB 750
2002 Electra Glide
2020 Honda CB500X
