CM77E Cases
BowlingSS
CM77E Cases
Post by BowlingSS » Fri Jun 23, 2023 11:01 am
Rebuilt the top end of my 1965 CM77 and the transmission is having problems. What is the easiest way to get the bottom case off? There is a lot of white glue holding them together.
Thanks.
Bill
1965 Honda CB77 Super Hawk
BowlingSS
Re: CM77E Cases
Post by BowlingSS » Fri Jun 23, 2023 6:57 pm
I am going to try heat first.
hillyhonda
Re: CM77E Cases
Post by hillyhonda » Sat Jun 24, 2023 12:23 pm
Ugh, nightmare. Only had this once, when I was much younger and more inclined to get mediaeval...
Is the stuff hard as nails or soft and flexible?
Cheers, Pete
BowlingSS
Re: CM77E Cases
Post by BowlingSS » Sat Jun 24, 2023 1:59 pm
It is like a silicon. It is not real hard. Cases are stuck really good.
Bill
hillyhonda
Re: CM77E Cases
Post by hillyhonda » Sat Jun 24, 2023 3:40 pm
Perhaps, just perhaps, sustained gentle pressure applied equally each side to separate the cases at front or rear might open up a gap enought to get, say, a scalpel blade started. Silicone tends to be quite heat resistant but petrol (gas) can attack it, trouble is getting it into the joint.
Sorry but I'm just guessing now - good luck.
Cheers
deuce_7
Re: CM77E Cases
Post by deuce_7 » Sun Jun 25, 2023 8:15 am
CM77 is a Honda model not familiar with. Can someone provide a description?
Thanks,
1967 CL77 305 Scrambler
BowlingSS
Re: CB77E Cases
Post by BowlingSS » Sun Jun 25, 2023 8:35 am
It is a CB77. Sorry.
