Will carb tubes (the carb to filter connector)for the cb77 fit the cl77?
They seem to have different part numbers so I assume they will not but I have seen vendors selling them to fit both and nobody seems to sell cl77 ones in the UK.
Thanks Greg
CL77 carb tubes
mike in idaho
Re: CL77 carb tubes
Do you mean the banjo fitting that is attached to the carb body with a hollow bolt? Both bikes use the same carb bodies, should fit the same.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
GregMcN
Re: CL77 carb tubes
Sorry if not clear Mike but no I mean the rubber/plastic tubes between the carbs and the air filters.
Greg
Greg
- Tim Allman
Re: CL77 carb tubes
Yes, they are different.
CL77
17253-273-000 Right tube
17353-273-000 Left tube
CB77
17253-268-030 Right tube
17353-268-030 Left tube
CL77
CB77
GregMcN
Re: CL77 carb tubes
Thanks Tim
Greg
Greg
