Case repair
Geoff Hastings
Case repair
As I had a bit of spare time I thought I'd try and repair a rather knocked about oil spinner cover. I used lumiweld, a low temperature ally repair. Using only a propane blow torch I ran into the damaged areas some of the Lumiweld, I then filed the surplus off and then wet and dry till level and then buffed it up. It's sort of OK, the Lumiweld is a slightly different shade so is visable, particularly the large area but the digs and scrapes look fine. The pictures are on flicker https://www.flickr.com/photos/148854602 ... res/A356Y8
- Tim Allman
Looks good. I have been thinking of doing the same thing as my oil filter cover also shows signs of riding my bike sideways. I think I'll do it.
BTW, Lumiweld is not the only supplier of this product. Bernzomatic sells the same thing (zinc with about 10% aluminium) and it can be found next to their propane torches. Maybe others sell it as well.
Geoff Hastings
Geoff Hastings
Mapp Gas should provide enough heat, I repaired the right hand case that was missing a lug. When I clamped it I made sure I insulated the case from the vice so the heat didn't soak away. Obviously the thinner parts are easier to get up to temperature but it's important to get to good clean metal, oxidised aluminium has a higher melting point and increases the risk of melting the item being repaired.
