Wiring Issue
Wiring Issue
Inside my headlight case I have a couple of extra wires not connected. The first one is the wire coming from the headlight parking light and the second looks like it might be the light for the speedometer. Does anyone know where these go?
- IMG_0877.JPG (30.38 KiB) Viewed 1934 times
- IMG_0878.JPG (28.33 KiB) Viewed 1934 times
You need to study the wiring diagram for your Dream. See
http://www.honda305.com/forums/ca77-wir ... t2633.html
revlover
The blue wire appears to be the high beam indicator. Look at your headlight wires there may be a double bullet connector on the blue wire where it goes. The same is probably true for the parking light. Look for a black/yellow wire coming from the ignition switch.
