Hi all,
I have been picking at this for a few days and can't seem to figure it out.
I have a 1964 CYB77 (no lights/electrical) and will be riding it on the street so have to add a tail light and a headlight to make it street legal here in Alberta. Headlight not installed yet
I added an original CB77 wiring harness and will add a small headlight under the front number plate.
My issue is, when the ignition is in the ON position, the brake light will not come on when depressing the pedal. If I position the key to the far right(rearward) position it works fine.
I wondered if its because the wires are not connected on the headlight?
Hope you have some input.
Thanks,
Rob
CB77 Tail Light/Brake Light
Chaindrive
Chaindrive
Re: CB77 Tail Light/Brake Light
Are all the wires connected to another wire.
If not what does your wiring diagram show they make work?. ...............lm
RobMcKay wrote:Hi all,
Thanks,
Rob
Just in case you do not actually have a wiring diagram, find it here. It's the second one on the page:
http://www.honda305.com/forums/viewtopi ... ng+diagram;
