CL77 Ignition switch retainer latch (plastic covered nut)
ScramblerFan
Post by ScramblerFan » Tue Mar 08, 2016 7:56 pm
I am in need of part number 17251-273-010 which is the retainer nut for the right side cover on the CL77. I have the ignition switch and switch retainer. Anybody have one to sell? Send me a PM if so. Thanks
Snakeoil
Post by Snakeoil » Thu Mar 10, 2016 2:56 pm
My experience is the plastic nuts crack due to creep over time. You are probably better off with something like this.
https://www.youtube.com/watch?v=qZOGlgVldAs
I have a brass knurled nut on mine that I nickel plated. I use a rubber gasket behind it to keep it in place and protect the paint.
regards,
Rob
zeerx
Post by zeerx » Mon Mar 14, 2016 5:19 pm
The nut that holds the lower tree though the steering head (not the top nut) is the same size and thread as the ignition. That's what I used. Might be easier to find one of those.
'99 ZRX1100
'05 DRZ400S
'66 CL77
'78 KZ1000LTD
'12 F-150 (Ford)
Post by G-Man » Mon Apr 11, 2016 12:10 pm
Re: CL77 Ignition switch retainer latch (plastic covered nut
Post by LOUD MOUSE » Mon Apr 11, 2016 1:23 pm
I see you say CL77.
May we have the frame number of the bike as the CL77 had a change in the size and thread of the part. .................lm
ScramblerFan wrote:I am in need of part number 17251-273-010 which is the retainer nut for the right side cover on the CL77. I have the ignition switch and switch retainer. Anybody have one to sell? Send me a PM if so. Thanks
ScramblerFan
Found one
Post by ScramblerFan » Mon May 02, 2016 6:10 pm
Dennis in Wisconsin had one in his extra parts and sent it to me. Thanks Dennis!
deuce_7
Post by deuce_7 » Fri Apr 20, 2018 5:06 pm
Resurrecting this thread after a site search because I have a similar issue:
Frame number: CL7710541xx
I have an ignition switch main retainer 35141-273-000
and
A right air cleaner cover latch/ignition switch trim ring screw 17251-273-010
There's a mismatch, because the trim ring screw does not thread on to the switch retainer. Looks like different thread pitches (?).
One or both parts are incorrect for this frame number. Does anyone have advice on the correct parts/numbers required?
I must have an older parts book, because it shows both parts I have as being correct.
Thanks for any advice.
