I need to pull my flywheel to replace my rollers and springs. Does anyone know the brand and part number of a good purpose built puller for the CB77?
Thank you
Steve
Flywheel Puller Question
Re: Flywheel Puller Question
Yes, you do. I'm not sure of the brand and part number of the one that I have, but, IIRC, I got it from Bike Bandit. It fits a LOT of different Hondas, including CB175/CL175 with the vertical cylinders, as I've used the same tool on those as well.Steverino wrote:I need to pull my flywheel to replace my rollers and springs. Does anyone know the brand and part number of a good purpose built puller for the CB77?
Thank you
Steve
This one should do the trick:
http://www.amazon.com/BikeMaster-Magnet ... uller+16mm
Having the right tool in the toolbox is a bit more convenient than pulling the rear axle.rrietman wrote:-you can use the rear axle to pull the rotor. or any other bolt with the correct rh threads.
Randy
But, this is good to know if you want to get the rotor off today, and don't want to wait for the tool to ship. It isn't likely you'll find an M16-1.5 bolt at your local hardware store.
