I have the headers, the spacers, the gaskets, and the 2 mounts. BUT I do need the 4 bolts that are needed to secure them all to the engine. Please if you have and extra set, let me know. Or the size needed.
Thanks, Dan
Need header pipe mounting bolts/skrews!
newcb77owner
6mm x 28mm stud is what the online fische says it requires. Most hardware stores have a small selection of metric studs, or you could use bolt of the correct leng. 6mm x 1.0 is the thread diameter and pitch.
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
newcb77owner
