Has anyone fixed a horn?
68Cb77
My horn made one beep when I put the bike back together, then quit. I checked and the wires had juice. I tore most of the horn apart, clean the contacts and cleaned the points that are in there.Put it back together, still is getting 12 volts, but just clicks once. That's as far as I have tore it apart. Just wondering if anyone has had this problem? Thanks, John.
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
82 Honda XR200R
70 Honda CB750 K0
kustommusic
kustommusic
68, OMG you are probably right,I was "shooting from the hip" on that one. OK I had to look this up. The horn should have 12 volts going to it with the key in run pos. The horn button will supply the ground to the horn to make it work. I apoligize for the misinformation,I guess its late or somthing. Now you should find the problem knowing how it works. Again sorry for the bum info the first time, you may beat me with an old wiring harness!! Kustommusic
