I just got my bike running tonight... took quite a few attempts starting, but it finally ran and fairly well at that, for having not been driven in 3 years.
Anyhoo, I noticed there's no kill switch.. but the signal switch decided to act as one when I tested out the signals.
Any ideas what's up with that? Seems like the bike isn't putting out enough charge.. would that be the rectifier?
Bike shuts off if I use signals or lights...
These bikes didn't put out alot of juice to begin with. Check to see if your light switch is shorting to ground. Sometimes the wires get pinched. It's a very simple wiring harness, so if you have a good multimeter you can make short work of finding the culprit. The rectifier is easily checked as well. Is your battery fully charged?
I have a multimeter.. but no idea how to test any of the connections.. :)
The battery was actually a little low.. it took quite a few cranks before the bike would start (since it hasn't been run in a few years), and I actually had to use a booster to get it going after than... so maybe the battery is still too low?
kustommusic
- h305 Moderator
Re: Post subject: Bike shuts off if I use signals or lights.
When the lighting switch is used, additional windings from the alternator (ok, dynamo) are switched into circuit to provide extra current to the lighting cct. Only one phase (coil set) feeds the rectifier to charge the battery with DC; the other two phases provide the extra lighting support, so I suspect you may have two issues here:
1. The black wire connection at the coupler block (beneath the tank?) feeds the horn, ign coil, winkers and stoplamp switch, so check that there is no corrosion / resistance / looseness at this connection
2. The primary phase (ie: charging via the rectifier) could have a 'dry' solder joint owing to motor vibration - I've had this myself, although switching the key to the lighting position on my old CB77 caused it to continue to run (see 1) - take off the alternator cover and visually check all the solder joints; be brutal, give the solid copper conductors a good wiggle to see if there's any movement at the soldering (or the wire might even be broken)
Keep in touch.
Steve Edwards
Keep in touch.
Steve Edwards
