Page 15 of 167
Posted: Mon Oct 06, 2014 9:56 am
by sarals
Great progress, Graham!
You know, the original air filters on my bike had the power jet connections (now that I know what they are). I think I tossed them, though - they were so disintegrated. I'll look see and let you know.
Posted: Mon Oct 06, 2014 10:32 am
by R100
I have what you show in the picture.
Two 6mm long 4mm bolts go through into the metal part of the foam rubber ring around the speedo.
My speedo is not attached to the foam rubber, so the tach and speedo cables push it up when the handlebars are turned.
Is that rubber ring originally attached to the speedo with adhesive?
G-Man wrote:R100
Depends which year your bike is. On post '63 Bikes there are two screws in the headlamp bucket which screw into two tapped holes in just below the speedo bezel.
Posted: Mon Oct 06, 2014 10:49 am
by G-Man
R100
Yes the speedo is bonded to the rubber.
Here's a replacement if yours is perished.
http://www.ebay.com/itm/Honda-CB77-CB72 ... 29&vxp=mtr
Posted: Mon Oct 06, 2014 10:53 am
by R100
Thanks.
Mine is actually in reasonably good condition, but no longer bonded.
First I will try and re-glue it.
Perhaps 3M weatherstrip adhesive.
G-Man wrote:R100
Posted: Mon Oct 06, 2014 11:09 am
by G-Man
R100
I would be interested to know how that turns out.
R100 wrote:Thanks.
G-Man wrote:R100
Posted: Mon Oct 06, 2014 12:00 pm
by cknight
The 3M weatherstrip adhesive will do fine, but can be a bit messy. Lately, I've been using the Permatex black RTV silicone. It holds the ring in place, and it's easier to deal with if you ever have to remove the mounting ring. Regards, Chase
Posted: Mon Oct 06, 2014 12:38 pm
by G-Man
Sara
There is a guy in UK VJMC who rebuilds them with new elements. If you still have them I would happily buy them from you.
sarals wrote:Great progress, Graham!
