Page 12 of 13
Posted: Thu Jul 26, 2012 1:46 pm
by Tango911
nice work on the dream, quite the task.
Posted: Thu Jul 26, 2012 3:47 pm
by Johnny5
Tango911 wrote:nice work on the dream, quite the task.
Thanks a lot!! First project I've ever finished, not perfect or original, but I thought it turned out pretty nice, especially when you know what I started with.
Posted: Sun Aug 19, 2012 12:14 pm
by Johnny5
Working on the clutch today, not quite sure what the problem is...and I haven't run into anything obvious yet...
There's no adjusting it, one way it slips and then adjust it tighter and it wont go into gear and it also gets really tight and wants to walk away from me when it gets hot. I'm at a loss any idea what the problem could be?
Posted: Tue Sep 18, 2012 11:06 am
by Johnny5
Just got my clutch apart...I couldn't find anything wrong, but I did notice that the clutch in the bike had 6 plates when the one that came out only had 5. I'm not sure why that is, but I'm going to put the 5 plate clutch back in and see if that makes a difference.
Posted: Tue Sep 18, 2012 11:55 am
by Tango911
u might want to ask around about what type of oil to use, the modern oils are more slippery and may be causing yoru clutch to slip. just a thought.
Posted: Tue Sep 18, 2012 1:57 pm
by Johnny5
Tango911 wrote:u might want to ask around about what type of oil to use, the modern oils are more slippery and may be causing yoru clutch to slip. just a thought.
Well I always use 30w non-detergent oils. I figured that's what it says on the crank case so that's what I go with. But if anyone had any input about the oil I should use.
Posted: Sun Oct 21, 2012 10:58 am
by Johnny5
Put the old clutch back into my bike last night. The one that was in it had 6 friction plates and the one I put back in had 5 thicker ones. But now instead of getting tight it slips when I try to kick start the bike. I figure the old clutch is worn out. I just don't know what to do with it now.
