Disassemble speedometer gear assembly
Post by LOUD MOUSE » Mon Jan 21, 2019 2:29 am
How will the grease get to the inside of the hub?. ..........lm
rrietman wrote:But--- go easy, you can blow grease past the seal very easily and then where is it? on the brake shoes. just lube on assembly. clean and repeat now and then.
Good luck
Randy
DJM
Speedo drive,
Post by DJM » Mon Jan 21, 2019 12:09 pm
I was just wondering the same thing?
rrietman
Post by rrietman » Tue Jan 22, 2019 12:20 am
was thinking of a different bike, sorry. my advice does apply to greasing the brake cams though.
Thanks
Randy
Post by LOUD MOUSE » Tue Jan 22, 2019 3:59 am
Not that I'm perfect however I do attempt to address the bike in question. ..........................lm
quote="rrietman"]was thinking of a different bike, sorry. my advice does apply to greasing the brake cams though.
Thanks
Randy[/quote]
Tim Allman
Post by Tim Allman » Tue Jan 22, 2019 11:04 am
The excess grease problem may be why the brake cam fittings are not found on the later models.
Post by LOUD MOUSE » Tue Jan 22, 2019 11:23 am
Or maybe found to not be necessary?. ..................lm
Tim Allman wrote:The excess grease problem may be why the brake cam fittings are not found on the later models.
DJM
CB72 Brake Greasing
Post by DJM » Tue Jan 22, 2019 11:36 am
Could be either or both of the above plus cost issues too.
Honda made more and more of thee models as the years went by and a few cents saved on each one would have mounted up.
