Alan,
Very interesting! I have a circular mark on the case which must have been caused by the clutch centre. I will have look on assembly and eliminate that as well.
My other issue is a persistent oil leak from the cover. Very unlike a Honda! I have had a go at fixing it before and failed. I plan to check the flatness of the cover. If that is ok, I may consider using 2 gaskets to see if that will fix it.
Regards,
Gordon
Primary Chain Wear
mcconnellfrance
Yes, I too have had oil leaks from the case in the past, a double gasket will probably work but I face the covers and the cases on a large 35mm piece of flat ally with double sided sticky tape and then 80 grit paper stuck onto it. This sounds a bit harsh but works well and I have not had one leak since I started doing it like this. You can use a piece of plate glass and grinding paste to face them, make sure you clean everything as you wouldn't want grit in the oilway. I hope this helps.
Cheers Al.
Cheers Al.
I had the same problem when I first got my CA. Found that the previous owner had installed the clutch pack with one thick fiber plate in a pack of the thin ones.AlanW wrote:I had a clicking from that case when the clutch was pulled in, it was the clutch center touching the cover were the oil feed is.
Al.
63 CA78
mcconnellfrance
