CB77 speedo/tach bulbs
Post by G-Man » Thu Oct 29, 2015 1:37 am
revlover
Post by revlover » Thu Oct 29, 2015 5:02 am
LM, According to a seller on ebay, the part # you gave has been superseded to
34902-259-003. This appears to be the part # for a 2 pack. So I may give the local dealer a try. Thanks again.
Post by LOUD MOUSE » Thu Oct 29, 2015 5:53 am
Very common change for HONDA parts.
003 only means the third generation of that part.
Thanks for the update. ..............lm
revlover wrote:LM, According to a seller on ebay, the part # you gave has been superseded to
revlover
Post by revlover » Fri Oct 30, 2015 8:36 am
I've found some suitable bulbs available at auto parts stores and RadioShack. The number is 1891 (14V 3.4W). The globe is elongated instead of round but it does fit the small holes in the gauge.
bulb
Post by LOUD MOUSE » Fri Oct 30, 2015 8:41 am
A GE 53 will work also. ..............lm
revlover wrote:I've found some suitable bulbs available at auto parts stores and RadioShack. The number is 1891 (14V 3.4W). The globe is elongated instead of round but it does fit the small holes in the gauge.
revlover
Post by revlover » Fri Oct 30, 2015 9:24 am
[A GE 53 will work also. ..............lm]
The 53 has the same profile as the Honda bulb, but only 1.7w. Might be a little dim for the already dark gauges.
