where do I acquire replacement screws JIS for a 64 305
border0_3
Post by border0_3 » Mon Mar 06, 2017 3:56 pm
Hi Paperslammer,
The most common JIS thread on these is the 5mm.
Look for a tap 5mm x 0.9pitch.
Be careful as many sell them as 5mm x 0.8 pitch, but this is modern ISO metric thread.
Cheers
DianneB
Post by DianneB » Mon Mar 06, 2017 4:44 pm
There was someone down south, Florida way I think, that was selling full sets of JIS screws for the 305 engine a couple of years ago. I searched my email but couldn't find him. It might be worthwhile to do some more internet searching. His prices were quite reasonable.
jkv357
Re: JIS Tap
Post by jkv357 » Mon Mar 06, 2017 5:13 pm
paperslammer wrote:I looked at their website, but didn't see any JIS taps. Does anyone know where to get JIS taps? On of the threads on my engine block is all gummed up.
Thanks
JIS screws are normal metric diameter (M5, M6, etc), the head however, is not a standard "Phillips" like usual.
It looks like you are talking a M5 tap for the dynamo cover, but the pitch doesn't appear to be what I would consider the "standard" pitch for that size.
malcolmgb
Post by malcolmgb » Mon Mar 06, 2017 5:15 pm
I posted a copy of the JIS to ISO thread pitch changes here http://www.honda305.com/forums/post8892 ... ght=#88920
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Re: JIS Tap
Post by LOUD MOUSE » Mon Mar 06, 2017 5:52 pm
Which hole has the JIS threads on your engine block?. ..................lm
Thanks
border0_3
Post by border0_3 » Mon Mar 06, 2017 8:13 pm
Hi LM. The block itself should have no JIS threads. They're all 6mm or 8mm. Unless I'm missing an oddball somewhere?
Nick
Post by Nick » Tue Mar 07, 2017 3:20 pm
Quick and dirty home-made taps:
File two flats 180° apart on the threads of a bolt or screw.
Carefully remove any burrs without rounding any corners on the flattened threads.
Heat bolt/screw red hot and drop into oil/water. Bolt/screw is now very hard.
You now have a nice home-made tap!
This technique can also be used to make chisels, punches and other tools where added hardness is desired.
