cleg wrote:Thanks guys. I ended up using a die grinder to get to some decent threads.
I have the left side together (a peek at LM's nice clutch). Does the stack on the crank look correct, before I tighten the nut with a spanner?
I've also attached a pic of my rebored and copper lined sleeves cylinder.
Thread size
Ya have the nut wrong side out. ..............lm
Tim Miller
Sleeves
Thanks Graham, Correct the reason for the copper plating is to buildup O.D of stock sleeve to achieve .003 to .004" interference for good heat transfer. Honda never had much if any interference.
It's all about the little details that make these little engines really run.
Tim
Tim
Tim
Thanks, thanks for sharing that. I'm always amazed how little heat is required to get the sleeves to drop out of the barrels.
I've got a set of barrels ready with Aluminum sleeves ready for Nikasil coating. I must get them finished.
- Tim Allman
