I kinda suspected that might be the case. The Kawasaki part is about 7 mm in diameter larger then the Honda cam chain tensioner wheel, but I don't think that will be a problem. I don't have an issue with the machining.
I do have a question about exchanging wheels. The fastener looks semi-permanent. Any helpful tips on RRing the fastenerer?
Also is there a substitute for the lower cam chain guide wheel?
Thanks for the help
confusion about cam chain guide roller
motobroker
Ya can get all the correct parts and only pay a fair price for them.
Or ya can go on the cheap and work the system in an effort to save a couple of $$$ and ask for help to do it.
Man I do love it!. ...............lm
motobroker wrote:I kinda suspected that might be the case. The Kawasaki part is about 7 mm in diameter larger then the Honda cam chain tensioner wheel, but I don't think that will be a problem. I don't have an issue with the machining.
Thanks for the help
motobroker
At this point, I am so beyond budget on this project, I am forced to pinch pennies in order to get it finished up in the home stretch.
I couldn't find a cam chain tensioner mechanism at any price, so I am glad to find out I can at least replace the wheel on it with the Z1 part. Any tips on how to replace it?
I will bit the bullet and shell out $45 for a cam guide wheel. Having worked at bike dealerships all my life, I am having a hard time swallowing paying that kind of money for a rubber wheel. But, I do certainly understand the rarity of NOS parts for this bike. I would also prefer not to use a NOS rubber part of undeterminate age and condition if I could find a fresher substitute.
- h305 Moderator
I'll be replacing mine with the one in the picture, but can do that this weekend if you're desperate. My old one is OK; I'm completely reconditioning the motor.motobroker wrote:At this point, I am so beyond budget on this project, I am forced to pinch pennies in order to get it finished up in the home stretch.
Which width screw centres do you have? The tensioner's width was changed at CB77E-1050999 (circa '66?) from 41mm to 32mm between fixing centres. Mine's the former.
PM me an offer if you're interested.
I have a way to save the rubber wheels as long as they aren't to terribly worn. .....lm
motobroker
