Page 2 of 9
Posted: Thu Jan 21, 2010 5:45 pm
by maia
Thanks, the pipes are Emgo "Dunstall" and I did pick up some knobs from Classic, great shop.
Posted: Thu Jan 21, 2010 6:35 pm
by maia
Frame, swing arm and most of the chassis is painted waiting on fork seals to assemble the front end and will then put it up on blocks with my new Hagons and start with the wiring harness. Wheels are going to be last.. .those hours of wet sanding and polishing...... .not looking forward to it. I have a new spoke set and I'm looking for alloy rims, anyone have a suggestion?
Posted: Thu Jan 21, 2010 6:43 pm
by LOUD MOUSE
Do ya have a drill press?. ............lm
maia wrote:Frame, swing arm and most of the chassis is painted waiting on fork seals to assemble the front end and will then put it up on blocks with my new Hagons and start with the wiring harness. Wheels are going to be last.. .those hours of wet sanding and polishing...... .not looking forward to it. I have a new spoke set and I'm looking for alloy rims, anyone have a suggestion?
Posted: Thu Jan 21, 2010 9:31 pm
by maia
Ya I do, why?
Posted: Fri Jan 22, 2010 7:47 am
by LOUD MOUSE
Now that ya ask.
Ya can use a 12 inch piece of All Thread Rod, (1/2 inch) 2 thread matching nuts and a couple if washers near the size of the bearing area of your hub and turning at a moderate speed (use coarse followed with finer grit sand paper) turn the finish to a really smooth finish then buff to shine. ............LM
maia wrote:Ya I do, why?
Posted: Fri Jan 22, 2010 10:56 am
by maia
thanks, I'll try it.
Posted: Fri Jan 22, 2010 9:17 pm
by maia
I've obtained these parts from a few sources and I think I have everything I need (handle and shaft not in photo) Can anyone direct me to a schematic that shows the correct order of assembly? My Clymer shows nothing to do with this. Thanks
