Just installed the kit this weekend. It is a very good kit for $16. Includes the crush washers for the 3 screws, new screen, gasket, Oring between petcock and tank, and both sets of rubbers for the petcock valve itself. Fit perfectly. As indicated before, I smeared a very thin layer of greas on both sides of the steel valve during assembly. It turns real easy, no leaks.
A great product, I highly recommend it.
PETCOCK REPAIR KITS
petcocks
What kind of grease did you use. I smeared some grease on mine the first time around and it was smooth but ,it didn' last long for some reason.I also used the crush washers provided and gas leaked out around the screws so I put the originals back on and they did not keak. Maybe I did not crush the crush washers enough.I like to shut the petcock off to run the bowl low and the more I rode the harder it got.
After you have the petcock off the tank as you are looking at the X which are springs and a plate they are on and two holes in the plate.The whole plate lifts out of the petcock assy.They can be a bugger to get up out sometimes.The rubber piece will probably come out with it and you will see how everything is positioned then.Pretty simple set-up.
i got my retrobike petcock rebuild kit for by 305....i have already torn the petcock apart and don't remember seeing two round rubber gaskets, where does the other one go, the one without the pipe looking thing sticking out of it....
does anyone have a drawing of the assembly or know where on the internet i can look at one????
jason
jason
