Guys - Will buying this solve my starting problems? will having electronic ignition alleviate the need to work on timing?
-Sascha
Electronic Ignition for CA77 Dreams - Available Now !!!
electronic ignition.
Set it and forget it.
I installed it on my 78 wing 6 years ago and haven't needed to touch it again.
David Sanborn
Electronic Ignition for CA77 Dream - Can't find ORDER link!
What's up with the Electronic Ignition for CA77 Dream modules? If they're discontinued it would be prudent to state as such, or at least give an ETA when more might be available. On a similar note, would you be willing to endorse another system, like either:
http://www.probe-eng.com/
OR
http://www.charlies-place.com/
As either of these looks worthwhile, but I'm sure I'll find that one is very preferred ...
Dave
OR
Dave
Finally got the ignition mounted. Took about three hours to mount everthing and run all the wires. I mounted the module to top of the frame under the seat. The unit came with 12 pages of instructions and you must wire it up per these instructions or take the chance of frying the electronics. After install and setting the timing it ran very nice and the motor would idle down to about 800 RPM without any problem. I still haven't taken it out on the road. Should have a test ride somtime this week.
David Sanborn
My CA77 Electronic Ignition Installation
AWESOME. Can't wait to hear your thoughts. Meanwhile, I'm documenting my install here: http://www.davesanborn.blogspot.com/SWARDLAW wrote:Finally got the ignition mounted. Took about three hours to mount everthing and run all the wires. I mounted the module to top of the frame under the seat. The unit came with 12 pages of instructions and you must wire it up per these instructions or take the chance of frying the electronics. After install and setting the timing it ran very nice and the motor would idle down to about 800 RPM without any problem. I still haven't taken it out on the road. Should have a test ride somtime this week.
dreamneworleans
E igniton CA77
I don't see where to order the kits. I have 67 dream 305. How much are they and how do I place an order?
