LED Tail/Brake Light Bulbs...
rgtaylor2
Post by rgtaylor2 » Thu Oct 02, 2008 10:10 am
I saw the LED tail lights at the local Advanced Auto yesterday with the 1157 base for $16.98.
Post by e3steve » Sat Oct 04, 2008 11:05 am
If your charging system is working as it was designed, using LED may cause you an overcharge problem because LED lights draw very little amps. The charging system does not have a voltage regulator so it is designed with the charge out put and drain predetermined. If you change either side of the equation you will throw it off balance. This is what happens if you ride your bike with the headlight burned out and the light switch on (it will overcharge). This is just my thoughts on it, I could be wrong……
Good, intelligent call, DD, but not the case, me ol' mate, so I have to disagree. I'm running one, along with a Philips 6-Watt* halogen parking light up front (for day running) and using the dimmer switch in the mid position**, flicking to dipped beam when appropriate attention to my presence is required (the most dangerous thing on Majorcan roads is the Majorcan driver!); I also have a 35/35 halogen headlamp bulb that fits directly into the original Stanley beam unit. My battery remains well-topped-up, charge wise, and I've not needed to replenish the electrolyte all season. Neither have I needed to externally charge it!
See my older post: http://www.honda305.com/forums/viewtopi ... highlight=
* it has offset pins, but can be forced into the lampholder with no damage and little effort
** not advisable in some US states, where the mid position gives both hi and lo beam filaments
paperslammer
Post by paperslammer » Sat Jun 19, 2010 7:57 pm
eyedragaknee, what bike do you have? I'm trying to figure out if the 1.8" LED taillight from Customdynamics would fit my 305 '64 dream. If you have the same bike, did you have to make any modification because 1.8" diameter seems HUGE to fit in that taillight cover.
Anyone else with an answer can chime in too!!!
Thanks!
