Page 2 of 24
Posted: Thu Aug 30, 2007 12:02 pm
by Dogsbd
Suh-weet!
I need to just send my wheels to you and have you re-lace 'em!!! LOL
Posted: Thu Aug 30, 2007 1:31 pm
by 4shorts
Dogsbd wrote:Suh-weet!
And you know I would do it for you too!
Posted: Fri Aug 31, 2007 10:35 am
by Dogsbd
Careful, I may take you up on that!
Oh yeah, I meant to ask: what is the name of that paint remover?
Posted: Fri Aug 31, 2007 6:30 pm
by 4shorts
Cecil the paint remover I used is made by Mar-Hyde and it's extra strength and fantastic stuff. clean and fast to use. I still bead blasted all the parts after because I like to etch the metal afterwards.
Today I got the metal work done and most of the body work. This time tomorrow she'll have a fresh coat of base clear pearl blue on her so that should be interesting. Later, Paul
Posted: Fri Aug 31, 2007 7:43 pm
by joeweir1
Hey Paul-Looks like your keeping busy.Just wondering, I have done alittle polishing on a small motor and wheel I got.Which color polish have you found best to polish with?Which buffing wheels are you useing.I have seen a few different ones with various napps to them, if thats how to descibe it?thanks Joe
Posted: Sat Sep 01, 2007 12:29 pm
by 4shorts
joeweir1 wrote:Hey Paul-Looks like your keeping busy.Just wondering, I have done alittle polishing on a small motor and wheel I got.Which color polish have you found best to polish with?Which buffing wheels are you useing.I have seen a few different ones with various napps to them, if thats how to descibe it?thanks Joe
Oh man I'm flat out on this end but it's a long weekend so I want to get as much done as I can with this C200.
Joe for a buffer I'm useing a 1 HP bench grinder with the guards and 10 inch stones removed. This guy is heavy duty and does the job perfectly for what I need it for.
As for the buffers, well I attached a picture of the type I'm using. I only use two colors of compound. For the rough cut I use the black one and for the fine I use the white one. I don't mix the two. One buffer for each color and that's all I use. I also found the if you use the paint remover on the parts before you stat to buff you'll get a better result. Might be there is some king of clear coat on the old part. Paul
