Posted: Mon Aug 10, 2015 4:56 pm
I am not absolutely sure but the plugs look slightly wet. There is gas in the float bowl and I have cleaned the carb a second time with no change.
https://www.honda305.com/forum/
DianneB wrote:I am not absolutely sure but the plugs look slightly wet. There is gas in the float bowl and I have cleaned the carb a second time with no change.
Fully. I charge it every time I have tried to start it.G-Man wrote:Battery charged?
Yup, checked them for continuity to set the timing. Then switched to electronic ignition with now change (but stronger spark) - didn't make any difference.Points clean?
Electric - my kick starter isn't working.Are you using electric start or kick?
ME TOO! I touched absolutely NOTHING between the last time it ran and when it wouldn't start any more!Just trying to think of things that may have changed since you had it running...... :-)
DianneB wrote:Fully. I charge it every time I have tried to start it.G-Man wrote:Battery charged?
