Steverino's CB77
alan curtis
centre stand hole.
Post by alan curtis » Wed Mar 11, 2015 3:35 am
Hi, its looking good, did you repair the centre stand hole, looks a little on the large size, you will have a very loose stand if you don't do. i made a little paper pattern, so as to get it it the right position both sides.. enjoying your posting.
Post by G-Man » Wed Mar 11, 2015 6:21 am
Alan
Well spotted. It won't sit nicely on the stand without.
Steverino
Post by Steverino » Tue Mar 17, 2015 8:44 am
Thanks Alan
You just saved me a lot of time trying to figure out the fitment problem I would of encountered upon reassembly. I know what I will be working on today.
Steverino
Post by Steverino » Tue Mar 17, 2015 1:09 pm
I checked on my David Silver Spares rim and spoke order today. I was not happy to learn everything is back ordered. DSS did not tell me they were out of stock when I placed the order. I sent an email requesting a ship date but I haven't got a response.
Steverino
Center Stand mount wear.
Post by Steverino » Wed Mar 18, 2015 1:53 am
I've never such an odd point of wear on a Honda before. This center stand mount just appears to me as not having a wide enough bearing surface for the load. Is this a common problem on the CB72/77's? It seems like it would be.
I think I'm going to build the mounting holes back up with my mig welder and direct a lot of cold air on it to keep from cooking my powder coat.
Post by G-Man » Wed Mar 18, 2015 2:25 am
Steve
This is not really a bearing at all. It is just that people do not tighten up the shoulder bolts properly or inspect them. The bearing is actually in the stand itself and the shoulder on the bolt should butt up solidly to the frame.
I am tempted to make an improved pivot by drilling out and threading inside the bolt and using a high tensile cap screw to hold it in place.
I've not found one yet that isn't worn.....
Steverino
Post by Steverino » Wed Mar 18, 2015 10:29 am
Thanks for the insight G Man. Loose bolts can create havoc on these spine frame Hondas.
I received an update from DSS regarding my rim and spoke order. I pasted a copy below. I have moved away from the ledge.
Hello Steve
Thank you for your e-mail. For your information when you purchase from our
website you see the live stock of both our US and UK stock. The wheel rim
was the only part which was being supplied from our Uk store and is due to
arrive @ the US warehouse on Friday. Sorry for the delay and we are working
with our software company to make the time scale clearer.
Best regards
Matt
