Page 64 of 142
Posted: Sat Sep 07, 2013 3:33 pm
by jerry
Dear Sarah, It is all very impressive what you are doing. I have really been enjoying the progress and the manner that you have logged the whole process on the forum. There are a lot who cant do what you are doing. It is all a credit to you and the people who have given you guidance and a bit of help. All the best Jerry
Posted: Sat Sep 07, 2013 4:24 pm
by sarals
jerry wrote:Dear Sarah, It is all very impressive what you are doing. I have really been enjoying the progress and the manner that you have logged the whole process on the forum. There are a lot who cant do what you are doing. It is all a credit to you and the people who have given you guidance and a bit of help. All the best Jerry
Jerry, thank you! That was very sweet.
I have one argument - with patience and perseverance, anyone CAN do this! Even me! ;)
Thank you again...
~~Sara
Posted: Sat Sep 07, 2013 6:39 pm
by jerry
Dear Sarah, You would change your mind if you saw some bikes being raced. I do agree with patience, perseverance, systems and proceedures. I think it is using what is between ones ears and a bit of talent. A bit like your chopper flying I think. All the best Jerry
message
Posted: Sat Sep 07, 2013 6:42 pm
by LOUD MOUSE
Good On Ya Jerry.................lm
jerry wrote:Dear Sarah, You would change your mind if you saw some bikes being raced. I do agree with patience, perseverance, systems and proceedures. I think it is using what is between ones ears and a bit of talent. A bit like your chopper flying I think. All the best Jerry
Posted: Sat Sep 07, 2013 7:30 pm
by sarals
Why thank you - both of you....yes, I'm blushing!
Posted: Sun Sep 08, 2013 12:50 pm
by sarals
Spent the morning installing the handlebar and the carb slides. Trouble! The carb slides won't drop into the carb bodies. Yes, the cutout is forward, which means the slides are going back into the carb bodies that they came out of, and the pin is engaging the slot on the side of the slide.. I don't think the throttle cable is routed properly, but that's not the problem. It's like the bores in the carburetors have gone out of round - the slides engage the keys in the bodies, move down to just about the venturi opening, and that's it. They're tight all the way from the top, not free sliding at all. I can shove them down, but they won't return on their own - either independently or both connected to the throttle cable. Those things should just drop in there, but they won't.
Posted: Sun Sep 08, 2013 1:16 pm
by LOUD MOUSE
Loosen the mounting nuts. ............lm
sarals wrote:Spent the morning installing the handlebar and the carb slides. Trouble! The carb slides won't drop into the carb bodies. Yes, the cutout is forward, which means the slides are going back into the carb bodies that they came out of, and the pin is engaging the slot on the side of the slide.. I don't think the throttle cable is routed properly, but that's not the problem. It's like the bores in the carburetors have gone out of round - the slides engage the keys in the bodies, move down to just about the venturi opening, and that's it. They're tight all the way from the top, not free sliding at all. I can shove them down, but they won't return on their own - either independently or both connected to the throttle cable. Those things should just drop in there, but they won't.
