Well, after a week "vacation", which included my last bicycle race of the season (I won!), I was able to get back to the Old Girl yesterday. I did some more painting, some more minor assembly, hunted for more parts (I need a hose for that breather on the top of the head), and pretty much finalized the installation of the electronic ignition.
I decided to mount the control unit of the ignition on the frame box section behind the engine. It will get the required airflow there, and it's mounted horizontally, as the instructions stipulate. If I need to move it, my next location would be the cavity in front of the battery. I'd have to fabricate a mount of some sort, but I can do that. Lastly, I could put it on the back of the horn, but that location causes a bit of a rat's nest with wiring. The trigger wires from the cam plate are in a braided sleeve, and they are long. If the controller was mounted on the horn, that trigger cable would have to be tucked out of the way near the coils somehow, and there it stands the possibility of picking up impulses from the coils, which the instructions say to avoid. So - the horn is the absolute last place I'd want to place the controller.
In the first photo you can see where I decided the place the controller. It's not mounted yet, it's just sitting there. There is more room for it than appears in the photo. I placed various final assembly items around it to make sure there was clearance, and there is - unless I missed something! The box will be attached to the frame with velcro.
The second shot shows the wiring from the controller to the coils. Yellow is for the left coil, blue is for the right. The green wires are ground, they'll be earthed to the same bolt that the ground strap from the engine to the frame is attached to. You can see how I fed the red wire through the sheathing to the headlight shell for 12V power - it will plug into the black wire in the headlight shell.
The third photo shows the whole deal all buttoned up. I'll trim the wires and get them attached to their respective terminals and mounts when I get the coils mounted, which will be after I find a hose for that breather pipe. And, when I am assured the controller will work where I want to mount it! I haven't checked the fuel tank for that wire bundle clearance yet, but I'm reasonably sure there is enough room for it.
